Adobe Contribute
- Everything else
- Adobe Contribute
Adobe Contribute
31-10-2007 1:34 PM
Hi
Has anyone used Adobe Contribute CS3 and would a current website not built in Contribute need 'modifying' or configuring to work with Contribute.
I have never used Contribute but it appears to be a fairly standard WYSIWYG editor.
Any assistance gratefully received
Dick
Dick
Message 1 of 4
(2,018 Views)
3 REPLIES 3
Re: Adobe Contribute
02-11-2007 10:16 PM
I cannot imagine wanting to use Contribute to update a website which was not created using Contribute templates because all the control and permissions features would be lost.
If you want to acquire a WYSIWYG page / site editor, probably better to look elsewhere (from Dreamweaver downwards; HTML-Kit for example is effective and free). Contribute is based on the idea of Dreamweaver templates which are areas on a page managed separately and which can be given update restrictions. The adminstrator creates pages built from templates and then sets permissions to certain users to upate specific areas. Contribute needs a server to control multi-user update access (with check out and check back in).
It is (or was) expensive in that each updating user (in addition to the administrator) needed a client access licence.
Zen from May 17. PN Business account from 2004 - 2017
Message 2 of 4
(146 Views)
03-11-2007 11:24 PM
Thanks decomplexity for your contribution...........
I will take it under consideration
Message 3 of 4
(146 Views)
14-11-2007 9:28 AM
I must confess that after playing around with Adobe Contribute I am not impressed and will therefore look elsewhere.
Message 4 of 4
(146 Views)
