Add exception in Plusnet Mcafee
rondon9897
Does anyone know how I can exclude a folder on my computer from any scanning/protection from the Plusnet Mcafee? The interface is really difficult to use and I can't find the right option.
Cheers
rongtw
Fixes: 12
Re: Add exception in Plusnet Mcafee
I dont use it , but is there not a option of Custom scan ? you should be able to chose in there
decomplexity
Intel's McAfee antivirus (etc) packages give very inadequate protection indeed and engender a false sense of security.
Kaspersky, Norton or Bitdefender Internet Security packages are far better bets.   Usual disclaimers
Zen from May 17. PN Business account from 2004 - 2017
Plusnet Staff
Plusnet Staff
Fixes: 117
Hi there @rondon9897 If you click on the Virus and Spyware Protection tab, and then click on Scan Your PC you should have an option to select a custom scan where you can exclude folders from a scan. I hope this helps you.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
