Accessing camera remotely?
chubsta
I have just moved over from Sky and wish to view a camera I have set up at home from another location. I have checked the IP of the router and that is updating noip.com - the ip address I get from the router (xxx.93.xxx.xxx) is the same I see if I go to my account on noip.com (xxxx.hopto.org resolves to xxx.93.xxx.xxx).
The camera is showing up as connected on the Hub Two screen and has an internal address 192.168.1.111 and can be connected to locally, but how do I connect remotely?
have to say it is a little disappointing to find out I cannot access the router itself remotely for admin purposes but I guess I will have to put up with that...
2 REPLIES 2
chubsta
Re: Accessing camera remotely?
Its ok, have just worked it out, cannot delete the thread though.
Did it by setting up DMZ...
Fixes: 1,495
Putting it in the DMZ isn't really advisable, you should create a port forward rule for it.
