Access to webspace when?
- Everything else
- Access to webspace when?
17-05-2008 3:40 PM
'This web address has not yet had a web page uploaded to it. If this is your web space and would like to know how to start building your website, you'll find lots of help from the PlusNet technical support section [more] "
How do I get past this or do I have to wait for some response from Plusnet. Do I have to delete or redesign the index.html and put a new link to the 'htdocs'? A help link would be appreciated if that is the case.
I have since authorised 'Front Page' which apparently does take several days, but did I need to do that?
Any assistance appreciated.
Re: Access to webspace when?
17-05-2008 4:04 PM
If you wish to use Microsoft Frontpage to build your site then enabling Frontpage Extensions as you have requested is required. However there are many other packages available that you can use to build a site without frontpage extensions enabled. You can easily turn off Frontpage Extensions again if you wish.
Customer and Forum Moderator. Windows 10 Firefox 87.0 (64-bit)
17-05-2008 5:44 PM
I'm happy to use IE7 as that can open the htdocs file. Does that mean I don't need 'Front Page Extensions' and is it best left 'off'?
I can edit the index.html but I've not seen any reference how to refer to the folders I have already uploaded and want to access from the web. Do I just delete the index file? Any pointers there would help me forward.
17-05-2008 6:02 PM
FTP is the correct way of accessing the files stored on the remote server
17-05-2008 9:58 PM
Strange non of the guides could mention that!
I renamed the index file and have now got www. access to my files and info from any computer. It contains .doc, .rtf , html, bookmarks and jpg which I can access with the necessary properties/permissions set. If I can read them I can use them or save them locally OK.
The idea is not to be able to modify the files, (which I can do on my base computer) but give me and others with permission to have access. I have tried some password protection but have not got that working yet. I need some further help on that so I will try again as a password protection should work conveniently. The trouble with having encrypted files using a programme is the need to carry a decrypt programme to get access. Any suggestions?
17-05-2008 10:18 PM
That because you are a Pre 68 Scout
Quote Strange non of the guides could mention that!
17-05-2008 10:40 PM
17-05-2008 10:59 PM
17-05-2008 11:10 PM
17-05-2008 11:54 PM
The simple way with the files is to zip them with a password as nothing is needed then you just tell your friends the password.
You can password protect directories on the server but if you have a lot of files and friends it may be a problem keeping up. If we had an idea of what you hope to do we could advise better
18-05-2008 12:24 AM
I did have straight access to my files earlier this evening using the www. address, the object being for others and myself to have restricted access to some files. Maybe it takes the server a while to update itself as now the password facility using the Webspace Guide and setting permissions via 'properties' has certainly stopped any www. access now (sadly I want it, and the permissions should allow it but no password is requested)
I can see '.' files in the normal Explorer in my computer but not in IE7 during ftp access. ( uploaded .htaccess .htpasswd using the Plusnet link http://users.plus.net/htpasswd/ ). So now I need to edit or remove those files. If I cant do it in IE7 then I'll have to use another ftp programme.
Thanks samuria for the zip password solution, that is something I'll have to try as it looks simple. I trust you can appreciate my objective now.
- Everything else
