Access to humbug outside of CGI server
- Everything else
- Access to humbug outside of CGI server
05-08-2008 9:50 PM
I have just been trying to reverse engineer my database schema and l'm having problems getting anything back.
I'm using hibernate and this is my db properties file - l'm logged onto the plus.net network and l can ping 'humbug.plus.net' fine.
<property name="hibernate.connection.driver_class">org.gjt.mm.mysql.Driver</property>
<property name="hibernate.connection.password">mypassword</property>
<property name="hibernate.connection.url">jdbc:mysql://humbug.plus.net/mydbname</property>
<property name="hibernate.connection.username">myusername</property>
<property name="hibernate.dialect">org.hibernate.dialect.MySQL5InnoDBDialect</property>
Can anyone see any problems with my properties? Or is it the case that you can not connect to the DB unless you are on the CGI server.
Regards, Gary.
Regards, Gary.
Message 1 of 2
(1,156 Views)
1 REPLY 1
Re: Access to humbug outside of CGI server
05-08-2008 9:52 PM
LOL - the second l posted this message - it's returned with all the table
Message 2 of 2
(321 Views)
- Everything else
