Access my ccgi website from my domain
- Everything else
- Re: Access my ccgi website from my domain
19-09-2007 12:28 PM
I have a domain name.. www.domainname.co.uk
I have a ccgi site http://ccgi.name.plus.com/
I have made a forum at this address http://ccgi.name.plus.com/forum
How do i make it so that if i click on www.domainname.co.uk it will redirect to http://ccgi.name.plus.com/forum
Thanks in advance
Thanks in advance
Message 1 of 7
(2,978 Views)
6 REPLIES 6
19-09-2007 12:38 PM
Message 2 of 7
(617 Views)
21-09-2007 2:40 PM
Hi, i have read this thread, but do not understand what i am supposed to be doing to allow this to happen.
Message 3 of 7
(617 Views)
21-09-2007 10:11 PM
Hello
Three things:
First the domain needs to point to ccgi: https://portal.plus.net/central/forums/viewtopic.php?t=52576
Then the .htaccess file needs to be put into ccgi.
And third, in the forum admin panel the new domain needs to be entered.
That's it.
Three things:
That's it.
Message 4 of 7
(617 Views)
22-09-2007 6:22 PM
Ok, so i have added this info to a .htaccess file..
Then i went to domain settings and added
www cname ccgi.plus.net.
Is this correct?
Quote RewriteEngine on
RewriteCond %{HTTP_HOST} ^www.mydomain.co.uk$ [nc]
RewriteCond %{REQUEST_URI} !^/forum/
RewriteRule (.*) /forum/$1
Is this correct?
Message 5 of 7
(617 Views)
22-09-2007 9:36 PM
Hello
The .htaccess file should work, though this is enough actually:
... because the one line is not required.
The Domain control settings are OK, this is what I had for a long time, and it is recommended in the tutorial (http://usertools.plus.net/tutorials/id/14). You could also use www a 84.92.1.4 (no trailing dot).
Now, don't forget to:
Hope it will work for you without problems.
RewriteEngine on
Quote Once you have done this, raise a "Contact Us" ticket to PlusNet support asking them to "Change the CGI service to basic" this will create the necessary records on the CGI and DNS servers to correctly point the domain to your files on the CGI server.
Message 6 of 7
(617 Views)
25-09-2007 9:35 PM
Thank you ,i have raised a ticket, which will hopefully get this resolved. Thank you for your time and patience
Message 7 of 7
(617 Views)
- Everything else
