Access MySQL Admin
- Everything else
- Access MySQL Admin
Access MySQL Admin
25-03-2010 9:44 AM
I have tried a multitude of browsers with no joy.
Could someone please explain what the problem is and if there is any workaround as it is essential that I am able to access this.
Whilst I do not want to make assumptions, it would seem that the page is unable to load due to high server load. If this is the case then what is the knock-on effect for sites that rely heavily on a database, such as a Joomla site or some other CMS?
Many Thanks!
Re: Access MySQL Admin
25-03-2010 1:32 PM
Are you using https://portal.plus.net/tools/phpmyadmin?
25-03-2010 2:18 PM
25-03-2010 3:03 PM
25-03-2010 3:42 PM
Can't see it being a firewall problem - perhaps something is not set correctly on your account?
Edit: just noticed it is 'https' on my url, 'http' on the one you posted.
25-03-2010 4:01 PM
Any suggestions?
25-03-2010 5:22 PM
Looks like there could be a problem with your account for which a ticket needs to be raised (or ring the CSC).
25-03-2010 5:39 PM
25-03-2010 5:42 PM
Phil
26-03-2010 9:45 PM
Thanks for your attempts to help so far.
26-03-2010 9:48 PM
There is one way I can think you could do it however. Set up remote support to one of clients PC's and connect to that, then use the browser on that to use mysql admin.
26-03-2010 10:00 PM
I will see if there is anything else that I can do before considering this but I will at least keep it as a potential option.
Thanks.
