AVG Warning
- Everything else
- AVG Warning
AVG Warning
07-02-2013 4:45 PM
I just attempted to go to my website and my anti-virus said it has a Blackhole Exploit Kit (Type 2371) and am completely at a loss as to how to fix it.
The website is gchristison.plus.com
Message 1 of 9
(2,140 Views)
8 REPLIES 8
Re: AVG Warning
07-02-2013 5:24 PM
First steps, upload temporary index.html to stop others getting infected. Change ftp password. Scan own PC for infection. There's a lot of it about.
Gabe
Gabe
Message 2 of 9
(649 Views)
Re: AVG Warning
07-02-2013 5:55 PM
Kaspersky isn't happy either
Message 3 of 9
(649 Views)
Re: AVG Warning
07-02-2013 9:28 PM
Nor Avast!
Message 4 of 9
(649 Views)
Re: AVG Warning
07-02-2013 10:56 PM
All very strange as I have not done anything to it for several years.
Message 5 of 9
(649 Views)
Re: AVG Warning
07-02-2013 11:24 PM
It's not what you've done to it, unfortunately your website has been hacked, and the hacker will have changed your files. The hacker may have gained access to the site by infecting your own computer perhaps with a key-stroke logger and stealing your password, or by cracking it.
This is why the first step is to make sure your own computer is not infected by malware, then change your account password - I think that also changes your Homepages website password. Make sure the new password is a strong one, at least 8 characters, not a dictionary word and include mixed case letters, digits and special characters.
Note that next time you connect your broadband you will have to use the new password; if you are using a Plusnet easy start router that should change automatically. You also need to use the new password to collect email from your default mailbox.
Hopefully you have a back-up copy of all files on the website so you can delete current ones (which are potentially infected) and replace them all with clean ones.
David
Message 6 of 9
(649 Views)
Re: AVG Warning
08-02-2013 12:42 PM
Ok have just removed everything from htdocs but left with a folder (logs) is that normal.
Message 7 of 9
(649 Views)
Re: AVG Warning
08-02-2013 2:06 PM
Yes this is normal. The logs folder is owned by and written to by the webstats processes that run in the early hours each morning to store access logs relating to your websites. You (or a hacker) shouldn't be able to write to that folder.
David
Message 8 of 9
(649 Views)
Re: AVG Warning
09-02-2013 11:03 AM
Having changed my password I set about attempting to upload the website with the new settings, to no avail. It would appear that changing the main password has not changed the website password because the old password works fine and the new one doesn't.
Message 9 of 9
(649 Views)
