ASP to PHP
- Everything else
- ASP to PHP
ASP to PHP
17-01-2008 1:06 PM
Does anyone know of a decent free ASP to PHP converter
I have a site which I didn't build which uses ASP extensively and I would like to trial run it on my PN webspace which doesn't support ASP but does support PHP.
I had a look at one, ASP2PHP but there must be more.
Any help gratefully received
Customer and Forum Moderator. Windows 10 Firefox 87.0 (64-bit)
Message 1 of 3
(1,180 Views)
2 REPLIES 2
Re: ASP to PHP
21-01-2008 4:32 PM
The problem with these converters is they very often convert in a "literal" way. In the same was that spoken language to language when translated literally make no sense, the same happens with computer languages. If its nothing too complex and you have a grasp of programming I would just get a good book and have a go yourself
Message 2 of 3
(176 Views)
Re: ASP to PHP
25-01-2008 4:29 PM
Quote from: Strat
The PHP site itself suggests ASP2PHP:
http://www.uk.php.net/manual/en/faq.languages.php
Have you tried the client-side version mentioned?
I've tried such beasts in the past and found the best thing was generally buying beer for a friendly developer and letting them take the strain
Message 3 of 3
(176 Views)
