ADSL Golden Ratio
FIXED- Subscribe to RSS Feed
- Everything else
- ADSL Golden Ratio
15-07-2020 11:07 AM
Is there such a thing as an ADSL Golden Ratio?🤔
I ask as there seems to be some form of correlation in that the up speed seems to be around a fifth of the down speed. 🙂🙄
Fixed! Go to the fix.
Re: ADSL Golden Ratio
15-07-2020 11:11 AM
@Leapy I dont think so, but there is a max upload speed, dictated by the technology used.
15-07-2020 11:30 AM
Both download and upload are affected by attenuation which increases with distance.
A "perfect" ADSL connection will have a download sync of 8Mbps, and upload of 880Kbps - so about a 10:1 ratio.
ADSL2+ will be 24Mbps down, 1.2Mbps up - so about a 20:1 ratio.
The upload frequencies are the lower frequencies so are attenuated a little less, so the ratios change with distance.
15-07-2020 12:49 PM
@corringham That sounds like a logical set of ratios😊 20:1 and 10:1.
In my area they advertise FTTP at 1GB down and 200mbs up or 5:1
I know that a lot of people never get their rated up speeds, so maybe that is a limit to the average "Golden Ratio"?
15-07-2020 7:19 PM
In my area they advertise FTTP at 900Mbps down and 900Mbps up or 1:1
15-07-2020 7:35 PM
@Champnet won't the same up and down impact on the effectiveness of the Asymmetric Digital Subscriber Line (ADSL)?🤔
With a perfect balance, up and down, at such a speed, how would you know if you're coming or going and it wouldn't be Asymmetric any longer either? 🙄
FYI:- Asymmetric not identical on both sides of a central line; unsymmetrical; lacking symmetry😉
15-07-2020 7:43 PM - edited 15-07-2020 7:46 PM
Apologies, it’s full fibre to the door. I was just comparing speed to your post above mine.
Advert here : Gigafast
