A second hosted domain on webspace
- Everything else
- A second hosted domain on webspace
20-07-2011 10:44 PM
I have for some time had a domain hosted by plusnet and although rudimentary got a website for that domain set up on my webspace. I now have a second domain hosted but can't figure out how to set up a different website for that second domain. Any help or pointers welcome.
thanks and regards
thanks and regards
Message 1 of 3
(1,022 Views)
2 REPLIES 2
Re: A second hosted domain on webspace
20-07-2011 11:31 PM
If you are thinking of websites hosted on your Homepages space you can separate them by using individual folders within /htdocs. You need to create DNS entries to specify the relevant folders. How to do this is explained in the Pointing your domain to another directory on the homepages server section in the Usertools Domain Records tutorial.
For ccgi it is still possible to use separate folders but .htaccess entries need to be used to redirect requests to appropriate folders.
David
Message 2 of 3
(304 Views)
21-07-2011 9:11 AM
Thanks spraxyt for the prompt reply. I knew it had to be simple
Message 3 of 3
(304 Views)
- Everything else
