A little help please
- Everything else
- Re: A little help please
18-03-2008 9:56 AM
Quite a simple question really, I would like to install an smf forum on my space, but a little stuck about the settings for the database.
where it says path you normally get away with "localhost" just wonder if that was the same using the dbs on plusnet ?
sorry if it is so simple.
but any ideas appeciated greatly
Message 1 of 3
(1,527 Views)
2 REPLIES 2
18-03-2008 10:00 AM
Firstly, ensure you have activated MySQL:
https://portal.plus.net/my.html?action=mywebsite&?membermenu=websitesettings and choose MySQL
You should get a confirmation email with your details.
The email will give you the hostname, username, dbname and password that you need to use. They will be something like:
hostname: rumpus or humbug
username: pn_username
dbname: pn_username
password: a7f89e09b8ca9
If you don't get an email within 4 hours of activating MySQL, raise a ticket asking for your details.
B.
dbname: pn_username
B.
Message 2 of 3
(363 Views)
18-03-2008 10:05 AM
yep got that, you answered exactly, many thanks barry appreciated very much
Message 3 of 3
(363 Views)
- Everything else
