550htdocs: No such file or directory
- Everything else
- Re: 550htdocs: No such file or directory
28-11-2012 9:34 PM
I last logged into my website four days ago.
I can log in okay but when I try to update htdocs I get the error message above. My website though is still live so the file is obviously there somewhere.
I also get the message 257 "/" is the current directory
The problem seems to have started when I tried to access the site using Filezilla, prior to this I used Ipswitch but I bought a new laptop running Win 7 which no longer worked except in XP mode.
For the time being I've given up with Filezilla after deleting all settings.
I have rechecked all connection details and they are correct, can anyone help please.
Barry
Barry
Message 1 of 6
(1,814 Views)
5 REPLIES 5
28-11-2012 10:47 PM
Hi Barry,
The permissions of the htdocs directory were dodgy. Give it another go now.
Message 2 of 6
(596 Views)
28-11-2012 11:07 PM
Thanks for that I can update now.
On the downside my website has disappeared leaving only the message:
Forbidden
You don't have permission to access / on this server.
Barry
Forbidden
Barry
Message 3 of 6
(596 Views)
28-11-2012 11:23 PM
Ooops! Sorry about that. What about now?
Message 4 of 6
(596 Views)
29-11-2012 1:19 AM
In FileZilla, after connection to homepages for me the last few entries in the message log are
Response: 257 "/" is the current directory
Command: TYPE I
Response: 200 Type set to I
Command: PASV
Response: 227 Entering Passive Mode (212,159,8,90,179,10)
Command: MLSD
Response: 150 Opening ASCII mode data connection for MLSD
Response: 226 Transfer complete
Status: Directory listing successful
The remote site listed in the right hand pane will be '/' with folder htdocs seen if you click the '+' against '/' to expand its contents.
Ticking Force showing hidden files at the bottom of the Server menu will ensure any hidden ('.') files such as .htaccess are made visible.
Command: TYPE I
Command: PASV
Command: MLSD
David
Message 5 of 6
(596 Views)
30-11-2012 8:46 PM
It's working just fine now Bob, thank you for your time and effort. javascript:void(0);
Barry
Barry
Message 6 of 6
(596 Views)
- Everything else
