530 Login Incorrect
Keithkkl
530 Login Incorrect
I can't get into my webspace
when i try to login it keeps saying
530 Login Incorrect
9 REPLIES 9
James
Re: 530 Login Incorrect
Hi Keith,
I've just logged into Bobs webspace without any problem.
Is anyone else seeing similar problems?
pierre_pierre
got  into mine with fire FTP - no problem
Keithkkl
No I still get the same problem
I go via ftp.plus.net
then enter details (same login as i do to get into member centre)
still get same 530 Login Incorrect
Keithkkl
I've just connected to my webspace via a ftp application (core ftp)
but before i could get in directly via the website ftp.plus.net but that doesn't seem to work anymore
Midnight_Caller
it works for me with Internet Explorer v6 to:  ftp://ftp.plus.net/htdocs/
and no problem for me with Internet Explorer v6 to:  ftp://homepages.force9.net/htdocs/
[Edit]
Spelling
jonasjackson
I'm having the same problem.
Midnight_Caller
Are you shore you put the correct Address in the Address bar?
To be shore click on my link, you will need to put in your Username & Password in the box that pops up!
[Edit]
What Browser are you using?
The following Browsers will not work:
Mozilla Firefox - But you can get a plug in for it.
Internet Explorer v7 I don't know if v8 or v9 will work.
Netscape
To upload files to your site, but you will be able to see your files! Except hidden files! for eggzampul .htaccess
jonasjackson
I've tried FireFTP, Internet Explorer (which normally works) and Dreamweaver.
abdou
Is anyone else having trouble with ftp'ing cgi space this morning? I'm getting 'connection refused' on ccgi.abdou.plus.com
les x
