3 accounts cant enable static IP's
cameldazzler
Hiya,
we have 3 new accounts with plusnet and we cannot get the static IP's enabled on any of them, i click activate ip and nothing seems to happen, is there some trick to it?
these 3 accounts where business accounts that we have moved to home accounts (as we like plusnet) all working well apart from the static ip's
Cheers
Daz
5 REPLIES 5
Fixes: 579
Re: 3 accounts cant enable static IP's
@cameldazzler yes, you post here and it gets picked up by a staff member🙄
The automated static IP activation has been broken for a while now.
One of the Plusnet Help team will be along shortly...
cameldazzler
ah ok thanks will await the staff!
MatthewWheeler
Fixes: 503
Hi @cameldazzler
If you can drop me a PM with the usernames in question I'll get that sorted
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
cameldazzler
will do thanks!
Fixes: 476
Moderator's note:
Thread moved from Broadband to Everything Else
