2 domains - 2 sites - Wordpress - Subfolders?
- Everything else
- Re: 2 domains - 2 sites - Wordpress - Subfolders?
- « Previous
- 1
- 2
- Next »
31-08-2014 9:26 PM
In my case uploaded media are in the default location so I guess I avoided having to change the path. In fact the path no longer appears in my dashboard settings - I think that came in with WP 3.5.
Hope setting up the second site goes well.
David
01-09-2014 6:57 AM
Here is my htaccess that is located in /public
RewriteEngine on
RewriteBase /
RewriteCond %{REQUEST_FILENAME} -d
RewriteRule ^(.+[^/])$ $1/ [R,L]
RewriteCond %{HTTP_HOST} ^(www\.)?oakfireplacebeams\.co\.uk$ [NC]
RewriteCond %{REQUEST_URI} !^/ofb/
RewriteRule (.*) /ofb/$1
RewriteCond %{HTTP_HOST} ^(www\.)?oakbydesign\.co\.uk$ [NC]
RewriteCond %{REQUEST_URI} !^/obd/
RewriteRule (.*) /obd/$1
The second half (oakbydesign - initial website) works! the first half (the 2nd website) gives an error of 403 forbidden.
My folders look like this
public
htaccess (as above)
obd
htaccess (works ok)
ofb
htaccess (see below)
I have changed the 2 urls in the database to http://www.oakfireplacebeams.co.uk using myphpadmin as well.
Sometimes?? i see the new website but it seems that the css is not there and therefore get a text like appearance?
htaccess for ofb is
Redirect 301 /pages/gallery.html http://www.oakfireplacebeams.co.uk/gallery/
Redirect 301 /pages/distributors.html http://www.oakfireplacebeams.co.uk/distributors/
Redirect 301 /pages/corbels.html http://www.oakfireplacebeams.co.uk/fixings/corbels/
Redirect 301 /pages/aftercare.html http://www.oakfireplacebeams.co.uk/
Redirect 301 /pages/style.html http://www.oakfireplacebeams.co.uk/your-beam/shape/
Redirect 301 /pages/colour.html http://www.oakfireplacebeams.co.uk/your-beam/colour/
Redirect 301 /pages/size.html http://www.oakfireplacebeams.co.uk/your-beam/size/
Redirect 301 /pages/extras.html http://www.oakfireplacebeams.co.uk/your-beam/extras/
# BEGIN WordPress
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /
RewriteRule ^index\.php$ -
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . /index.php
</IfModule>
# END WordPress
I have better-wp-security plugin installed, I will try and rename/uninstall this if necessary?
Richard
01-09-2014 3:04 PM
My suspicion is that the /public/ofb folder doesn't exist, or it does but the web server can't open it. If one requests /ofb without a trailing slash the first rule doesn't add one which implies that isn't a directory. Also a 404 Not Found results. (Trying the same with the working domain and /obd does result in a slash being added and a page displayed, though page content is missing because links will be messed up).
Concerning the rules overall. The root .htaccess file adds missing trailing slashes twice which shouldn't upset processing but adds unnecessary complexity I suggest using the following which includes explanatory comments.
Quote from: oakbydesign RewriteEngine on
RewriteBase /
# Ensure trailing slashes are present on all directory URL requests
# Rewrite oakfireplacebeams into its own subfolder
# Rewrite oakbydesign into its own subfolder
For the subfolder .htaccess the presence of those hard redirects rings alarm bells to me. I'd be seeking to use mod_rewrite directives to achieve this. Are they required because the site had been redesigned but search engines might have old links?
David
01-09-2014 3:41 PM
I have changed the root htaccess file as requested.
The /ofb does exist see attachment
Here is the htaccess within the /ofb folder
# BEGIN WordPress
RewriteEngine On
RewriteBase /
</IfModule>
# END WordPress
I have also changed the 2 areas in the wp-options table with myphpadmin (site url and another) to http://www.oakfireplacebeams.co.uk
I have checked all other settings I can think of, replicating the oakbydesign settings (obviously replacing them with oakfireplacebeams where necessary.
I think it might be a plugin called better-rp-security although I have removed every trace of it for the tables and ftp.
If the htaccess code above looks ok, can you talk be through a 'backup and install' the oak fireplace beams website?
I really need this to be LIVE tonight
Many thanks
Richard
PS If I try to access http://ccgi.digger.plus.com/ofb/wp-admin/
it redirects me to
http://www.oakfireplacebeams.co.uk/wp-login.php?redirect_to=http%3A%2F%2Fccgi.digger.plus.com%2Fofb%...
Could this help you?
01-09-2014 7:50 PM
So why doesn't yours?
Perhaps it does but there's a problem with your site (code or Hostopia configuration). I think I'd try temporarily renaming the WordPress /ofb/index.php and replace it by a simple page containing (say)
<?php
echo "<h1>Hello there!</h1>";
Then see if that displays OK when referenced as
www.oakfireplacebeams.co.uk/ofb ; and
The .htaccess in my WP folder (created by WP itself) is identical to the one you listed - and my site works - so that should be OK.
If I use your account URL with /ofb (no trailing slash) one is added and originally an empty page resulted, but now it looks like I get the intended page but with missing CSS. The page seems built from lots of JavaScript.
Do the same with /obd and the normal header displays with "Page not Found - Click the Logo" content.
I'm sure there must be a clue somewhere amongst all this but …
David
01-09-2014 8:02 PM
Many thanks for your persistence.
Using the new index.php file with "Hello There!"
The results are
www.oakfireplacebeams.co.uk - Forbidden 403 error - You don't have permission to access / on this server.
www.oakfireplacebeams.co.uk/ofb - Not Found 404 error - The requested URL /ofb was not found on this server.
ccgi.digger.plus.com/ofb - It Works!
Then converting it back to the original index.php
The results are the same but, as you said, the ccgi.digger.plus.com/ofb loads the menus etc, without css?
Richard
01-09-2014 8:15 PM
There was a big mix up back in June and I was given or created 2 log on names.
ccgi.digger.plus.com AND oakbydesign.co.uk ?
I only use the ccgi.digger.plus.com, however, when I look in the oakbydesign.co.uk's account, I have a matching database for oakbydesign.
I have also tried to create the oakfireplacebeam database under both users but nothing.
Thought this might help?
The bandwidth vary a lot. ccgi.digger.plus.com is as shown. The other is nearly 4800MB !
01-09-2014 8:25 PM
Time for a chat with Plusnet I think.
David
PS I was just about to post this, though maybe you've identified where the problems are. But I'll post anyway. About to go out now…
01-09-2014 8:28 PM
As I cannot login to the dashboard, I used myphpadmin and changed the site url and another value in wp-options to ccgi.digger.plus.com/ofb/
It sort of works but the links are still not working.
Try ccgi.digger.plus.com/ofb/
Richard
01-09-2014 8:30 PM
Will you keep me updated after speaking to PN?
Regards
Richard
01-09-2014 11:45 PM
Sorry but contacting Plusnet will have to be done by you. They won't discuss another user's account with me. I suggest raising a Plusnet Hosting (CGI) ticket at https://www.plus.net/wizard/?p=wizard&page=23097&wizard_id=38 briefly explaining a server configuration problem is suspected with those domains and referencing your reply #20.
It looks like the problems you encountered earlier this year might not have been completely resolved.
David
01-09-2014 11:52 PM
Please do post back if you get a resolution - I was hoping there would be one. You've got me at it as well here!
02-09-2014 9:16 AM
Ticket sent.
Will keep you updated.
Richard
02-09-2014 4:52 PM
Apparently, when you change the DNS server to point to hostopia it will propagate after 4 hours or so AND you need to ADD the domain to the Cpanel. I was unaware of this.
Nothing was mentioned about having to raise a ticket to PN and then ask them to add the domain name manually.
Very frustrating but sorted.
Thanks for all your help
Richard
02-09-2014 5:18 PM
The site now displays fine with no indication in the address bar of the underlying physical file paths.
David
- « Previous
- 1
- 2
- Next »
- Everything else
