2 Accounts - CCGI and CGI - Which to use?
- Everything else
- 2 Accounts - CCGI and CGI - Which to use?
20-02-2014 8:33 PM
I seem to have two accounts created. One starts ccgi and the other cgi. I'm guessing it should be ccgi as all references I see in the migration notes refer to ccgi.
Message 1 of 6
(2,033 Views)
5 REPLIES 5
Re: 2 Accounts - CCGI and CGI - Which to use?
21-02-2014 9:46 AM
The physical space each maps to is this same so it doesn't really matter. There are separate instances of the MySQL/FTP Manager etc. however the File Manager for each should be the same?
Basically http://cgi.username.plus.com and http://ccgi.username.plus.com point to the same place.
Does that make things a little clearer?
Message 2 of 6
(521 Views)
21-02-2014 12:24 PM
Thanks Bob. Yes that's clear. I noticed that what I did on one seemed to match the other but good to have that confirmed.
Message 3 of 6
(521 Views)
22-02-2014 6:37 PM
I too see both a ccgi and a cgi and from the above posts I now know it doesn't matter which I use, so I'll stick with ccgi but I have another question about cgi duplicates...
If I use the File Manager to look at the directory structure then in the left hand pane under \publc I see a folder called \CGI-BIN and a folder called \cgi-bin but in the right hand pane only the \cgi-bin folder is listed. The contents of \CGI-BIN and \cgi-bin appear to be the same (some pictures and a folder holding thumbnails). Is that the way it is supposed to look? Or can I delete \public\CGI-BIN and leave only \public\cgi-bin. Or should I delete both because above \public in the left hand pane, i.e. within the root \ folder, there is another \cgi-bin folder (that one is empty).
stuck
stuck
Message 4 of 6
(521 Views)
22-02-2014 7:32 PM
On Plusnet ccgi /cgi-bin was just an ordinary folder within the webroot ( / ). On Hostopia the webroot is /public and (the currently empty) /cgi-bin is parallel to it. So a relative reference from the webroot to ./cgi-bin wouldn't work. In case users have code that uses such references Hostopia have created directories to suit.
A URL like http://domain.com/cgi-bin/myprog.pl will be directed by the server configuration to the real /cgi-bin (which is empty). To cope with that you should find there's a .htaccess file in / with a mod-rewrite directive to send the request to /public/CGI-BIN/myprog.pl. However /public/CGI-BIN is a soft link to /public/cgi-bin where myprog.pl will be found.
It sounds complicated, but does/should work (hopefully my logic is correct
If you are satisfied none of your code requires /cgi-bin to be below the webroot (/public), and its contents do not include any PHP files you can move the content of /public/cgi-bin to the real /cgi-bin, remove /public/cgi-bin and /public/CGI-BIN, and disable the .htaccess in /. The site should then function normally.
However it's up to you whether you want to follow this through, only yourself knows how your site works.
David
Message 5 of 6
(521 Views)
22-02-2014 8:08 PM
Quote from: spraxyt ....only yourself knows how your site works.
However, thank you, from what you say I think I can safely pull the plug on the both of my \public\cgi-bin folders.
stuck
Message 6 of 6
(521 Views)
- Everything else
