will a fax machine work?
I'm going to buy one of those linksys boxes for plustalk, just wondering if a fax machine would work plugged into the linksys thingy?
1 REPLY
Yes should work. If you search this forum others have posted that fax worked okay. The Linksys PAP2 has specific settings for fax.
