what is PlusTalk 240
fistsbs
I can not find any information on PlusTalk 240,
I have a new PlusTalk icon in my accounts page, whats it for?
I think that if i click the new PlusTalk icon i will get 240 free min's
It would be nice for some one at plusnet to post information on this new option.
Assuming you have already activated PlusTalk and you had a PlusTalk Account icon then what the new icon means depends on which product you are on. If you are on Premier then it is PlusTalk240 and if you are on PAYG then it is PlusTalk120.
I think I have the same question, what is PlusTalk 240? I can find out all about PlusTalk, I just can't find out what the 240 package entails?
I apparently now have PlusTalk 240 included with my ADSL subscription, but without knowing what the package entitles me to it isn't much use!
240 minutes of free anytime PlusTalk VoIP calls to UK landlines each month.
Included minutes can only be used to call 01 & 02 UK landlines
Does thia mean that I can call from my PC (using VOIP) to a non PC 01 number phone for upto 240 minutes a month?
waitenet
Yes you can only dial numbers begging 01 and 02 on Talk 120 or 240, you have to put credit on your account to use any other number.
You cannot dial numbers begging 05,07, 08 or 09 using your included free minutes on Talk 120 or 240
