welshchris.plus.com - got a virus???
stewarta13wsb
According to my firewall, welshchris.plus.com tried to access my computer 62 times last week :shock:
Does that make him a hacker or a poor soul with a virus who doesn't know it??
Looking back over the logs there are actually quite a few plus.com addresses in there (although not usually as many attempts!) Why are they there? What does it mean?
EDIT: Found another 'regular offender' - dominicpriestly.plus.com - umpteen attempts from him too :?: :?:
MysteryFCM
Did they actually try to access the machine, or are they just ICMP packets?. If you are unsure, please get yourself a traffic monitor such as "What is Transferring" and keep an eye on the packets.
http://www.wfshome.com/wit.htm
Look at it this way, if they where logged by the firewall, they not get through!
The most likely explanation is that they have a virus on their machine, if some one was attempting to hack your machine (targeting your personally), you would see connections attempts to a large number of port in a short space on time.
Viral activity general only uses a small number of ports but over a longer time. Until they remove the virus.
This is only very basic rule of thumb.
The reason that all attempts look like they are coming from *.plus.com machines, is because Plus.Net block most inbound attempts at their perimeter.
Chilly
stewarta13wsb
Don't know what they are Shockedops: but another look at McAfee logs says they are 'ICMP Pings'
...and as Chillypenguin says they didn't get through, so no worries - I was just curious.
MysteryFCM
You can generally ignore ICMP pings anyway, just as an FYI .... or do as I do and block them at the router/FW Smiley
You could always email the guy to let him know !
shellsong
Or PM them! "Did you know your computer is trying to seduce my computer!"
