webspace limit?
webspace limit?
Is there a limit for the number of visitors to ones web space?
Is it measured in the amount downloaded from the web site and if so, what is this limit?
webspace limit?
There is not limit to the number of visitors but there is a limit to the amount of bandwidth your site generates (i.e. people downloading your webpages and images). This varies depending on your account type and it normally the same as your website space limit, which for home accounts is 250MBytes/day downloaded.
If you exceed this download limit over a number of daye, your site will normally be blocked and you will be asked to take steps to reduce it (by reducing images sizes or removing files from your website).
webspace limit?
thanks for the info,Peter..
