webspace fresher
webspace fresher
I've just discovered 'My Webspace' freebie from PlusNet. I've downloaded CuteFTP and copied over some .jpg files to the htdocs folder by using the upload button. I've refreshed, disconnected etc etc but when I go to my allocated domain name www.username.plus.com, the standard PlusNet Webspace page comes up, what am I doing wrongHuh Please help!
megadyptes
webspace fresher
Have you changes the index.html file located in the htdocs folder? By default it contains a redirect to the plusnet page you describe.
webspace fresher
Well I messed around with it...I changed it to read my web address but that did not work either
megadyptes
webspace fresher
By "messed around with it", do you mean your index.html file now reads?
<html>
<head>
<META HTTP-EQUIV="Pragma" CONTENT="no-cache">
<META HTTP-EQUIV="Expires" CONTENT="-1">
<meta http-equiv="refresh" content="1;url=http://www.hussains.plus.com">
</head>
<body>
</body>
</html>
Or have you added the tags to link to the .jpg files?
LiamM
webspace fresher
If you delete the index.html file you should get a directory listing of the files to view/browse.
