web cam on line
web cam on line
can anyone tell me how to set up my web cams so that i can watch them from anouther computer in a differant location i currently have web cam xp pro and a dlink router.
yours phil
web cam on line
One option is to use a program to upload images from the webcam to your webspace every so many seconds. This will not give you a streaming image. But if you are using your webcam to provide a view of a fairly static image then it works.
I use a free program called fwink to upload the webcam images on my site, every 30 seconds.
www.chillypenguin.org/webcam/
Chilly
web cam on line
There are a few good ones.
Teveo is good, and for macs, macam rocks.
Those are best i have found. Id go with macam for macs because its so amazing. Both these packages stream via java applet, and offer logins and http connections. Bare in mind that teveo can be unstable at times if your pc sleeps.
