voip
voip
can plusnet have a x-lite build just like sipgate has
its so easy all you do is run the software and your on no settings to fill out, its done for you. im sure you guys at plusnet can get this sorted out unless you want to loose custom to rival voip providersHuhHuh
any plans to do one makes phone calls easy
1 REPLY
voip
Hey Stu - small world, guess you got your VOIP sorted!
Will have to show the girls how to use the free calls now.
p.s. got the utstarcom f1000g phone from sipgate, and that came pre-setup too!
those guys have thought things through.
Mark
