using sip into Plustalk
I have a deesktop and a laptop on which I have configured Plustalk I can put messages in and I can retrieve voive mail so I am assumng that the thing is set up right.
I am taking my laptop abroad - how do I connect to my desktop and make and recieve calls to and from these machines
1 REPLY
powernumpty
Install something like gizmo (gizmoproject.com) on the laptop then use
sip:plustalk@yourusername.plus.com or **768(yournumber) to connect back to base.
Gizmo uses sipphone so you will get a sip service you can use anywhere.
The laptop can't use plustalk if it is connecting via a non plus connection (I.E. over seas)
I see sipphone is peered with plustalk so the two should talk easily.
I just tried from Gizmo to plustalk but looping back to another phone on the same network is not a good test (it workled but I couldn't sort the audio)
