uploading problem
uploading problem
Shockedops:
Hi.
Just arrived at PlusNet from Tiscali. Smiley
I`m having problems getting my set uploaded.
I go to www.iedwards123.plus.com but keep getting directed to http://webspace.plus.net/webspace_plusnet.html
I`m using dreamweaver if this helps?
Eddie
Julie
uploading problem
Make sure you have uploaded your site into your htdocs directory on the server.
You also need to make sure that the your main page is called index.htm or index.html
Dreamweaver works fine to upload files, but I have found that I get on much better using a FTP client, it gives me more options Smiley
Hope that helps you solve your problems.
uploading problem
Sorted it.
I had 2 index files for some reason :roll:
index.htm and index.html
One of these was blank.
It works now.
http://www.iedwards123.plus.com/
Here`s my link
Eddie
