*.tk problems?
*.tk problems?
Hey,
For some reason, i cant access any *.tk domains, is anyone have the same problems? because my friends arnt, and they dont use plus.net, so anyone have the same problems, is it +net, or is it my account? if so what could be wring,
and use www.dot.tk to test if it happens with you,
Tim
*.tk problems?
works for me @ 1:45pm 12/6/04
*.tk problems?
ok, so what is the problem here?
*.tk problems?
tracert the site.. and post it.. see if we can see any errors or bad hops
*.tk problems?
what?
*.tk problems?
Start->run and enter cmd (or command) in the box and click ok, this will give you a DOS window. Then type tracert www.dot.tk and cut/paste the output here so we can see where it is failing.
This is what I get (the ---- are to stop line wrapping):
C:\Documents and Settings\Peter>tracert www.dot.tk
Tracing route to www.dot.tk [62.129.131.33]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 15 ms 17 ms 16 ms lo1.homesurf.pth-ag2.plus.net [195.166.128.34]
3 16 ms 17 ms 16 ms gi1-2.vlan16.pth-gw4.plus.net [212.159.1.241]
4 20 ms 16 ms 16 ms gi1-2.vlan16.pth-gw3.plus.net [212.159.1.244]
5 16 ms 17 ms 16 ms lon1-10.nildram.net [213.208.106.89]
6 16 ms 15 ms 15 ms GigabitEthernet5-0.linx2.lon1.level3.net [195.66.226.77]
7 15 ms 15 ms 16 ms so-1-3-0.gar1.London1.Level3.net [212.113.3.25]
8 17 ms 16 ms 16 ms so-7-0-0.mp1.London1.Level3.net [212.113.3.1]
9 18 ms 16 ms 17 ms 4.68.128.110
10 20 ms 16 ms 18 ms ge-11-1.ipcolo2.London2.Level3.net [212.187.129.182]
11 17 ms 19 ms 16 ms BT-NET.ipcolo2.Level3.net [212.113.11.254]
12 23 ms 27 ms 29 ms t2c2-p10-0.nl-ams2.eu.bt.net [166.49.195.34]
13 24 ms 24 ms 25 ms t2a1-ge6-0.nl-ams2.eu.bt.net [166.49.200.17]
14 27 ms 23 ms 24 ms 166-49-210-2.eu.bt.net [166.49.210.2]
15 23 ms 24 ms 23 ms pos0-0.gsr01.virtualxs.net [62.129.128.1]
16 41 ms 37 ms 34 ms HOSTED-BY.DOT.TK [62.129.131.33]
Trace complete.
*.tk problems?
It opens commant pront up, then, just wait for a bit, without saying anything, and then quits, also when i try and ping it, it dosent work either
*.tk problems?
What windows version are you running?
When you click the start button, then click run, what are you entering in the box before clicking ok.?
This must just be cmd for WinXP or command for Win9x/Me then either press the return key or click the OK button. This should open a black dos box (window) with a c:> prompt, where you can then enter the tracert command.
*.tk problems?
i use xp pro, and i typ cmd to go to commant promt in the run thing, and in command promt, when i try
tracert www.dot.tk
, it says,
Unable to resolve target system name www.dot.tk.
And in Command promt, when i put:
ping www.dot.tk
It says:
Ping request could not find host www.dot.tk. Please check the name and try again.
So what should i do?
Thanks in Advanced,
Tim
*.tk problems?
Try clearing out your DNS cache:
C:>ipconfig /flushdns
Then try the tracert command again.
Post what the following command gives you:
C:>ipconfig /all
Also post what the following command gives you:
C:> nslookup www.dot.tk
