sending live webcam images to webspace?
hi all, if it is possible i would like to be able to use my webcam for home security purposes whilst away from home by leaving it running and be able to monitor over the internet from other locations. can anyone advise in some detail if possible how i would go about this. i will use my +net webspace if that is feasable. many thanks dave..
Webcam
HI,
You could try www.chillcam.com . The download lasts 160hours, which gives you plenty of time to setup/ test. It can live video stream or ftp upload jpg's, and the software has a motion detection trigger setup as well. HTH.
Cheers,
Gavin. Cheesy
I have used webcamxp before, Very good.
