"Universal" Instant Messaging Clients
I'm trying to find a good (and preferably free) "universal" instant messaging client.
Minimum requirements are to run on Win98SE and work with MSN, AOL and Yahoo Messenger services.
Anyone got any experience/suggestions that might help?
thanks in advance
GAIM? I've used it on win 98 in the past an I belive it does all 3 protocols i know for sure it does MSN and AOL
Ah! Sourceforge! I should always go there first before asking questions like this ... think I'll make my homepage.
thanks Daniel Cheesy
there also some really nice Gaim plugins, however you cant do audio/video over msn/aol with it yet Sad
just installed it and it's pretty nifty, although shows the pawmarks of those who are not yet entirely familiar with porting *nix to windoze.
But it'll do nicely, and doesn't have the hideous bug of MSIM which generates 0-byte tempfiles by the (literally) thousand ...
wish i could find out how to display photos like in MSIM though ...
thanx again
tools -> preferences -> tick "show buddie icons"
plugins you will want :
wingaim options
system tray icon
both can be got from the gaim site Smiley
this is cool, i'm overwhelmed with help ... got the extended options thanks but can't locate the "system tray icon" unless its lurking about under a different name/description.
is there a different word for "thanks" so I don't sound so unimaginative?
paul
er in my plugins its just called system tray icon
Windows Gaim FAQ
* What happened to the Gaim systray icon? - As of 0.65 systray functionality has moved into the docklet plugin, labeled "System Tray Icon" in Gaim's plugins section (under Preferences). You will need to load this plugin for the systray features to work.
Hope that helps
Trillian, im on it and love it.
@buzzons i thought you meant a downloadable plugin so that was the confusion ... thanks anyway.
it really is neat, and I'll continue to use it in pref to MSNIM, but there there are fantastically irritating UI probs because of the 800x600 res I have to use on my 7-year-old laptop ... which isn't going to get replaced any time soon. So will d/l Trillian and have a go with that as well
cheers
GAIM has a far lighter footprint that tillian :S so you may see mass slowdown etc with it.
Yeah, and it crashes! But gaim turned out to be unusable beyond my first infatutation, on my machine, so despite a bit of instability and lethargy (altho this is mostly in the speed with which the menus drop down) I'm using Trillian now. Much nicer UI too.
boo!
i know. i'm such a slapper when it comes to software. i go for pretty over clever every time ...
