problem with frames
problem with frames
HELP HELP HELP!
Im tring to make a website and am learning frames. Ive got my main page which has a left frame and a right frame. In the left hand side i want to place links that will open in the right one, but cant figure out how too.
Can anyone help me? :?
problem with frames
That requires a minimum of three files.
1: the frameset
2: The left frame
3: the right frame
In the frame set, you need to give each "<frame>" tag a "name" atribute".
In the left navigation frame, each link must have a "target" attribute. This should be set to the name of the right frame.
problem with frames
Where do i place the "target" attribute and does it have to be on every link i want to open in the right frame.
problem with frames
You can place targets on links (including all the link inside the right frame), or alternatly, use a <base> tag.
This should be in the <head> section of the HTML document and read somthing like
<base target="framename">
problem with frames
Got it, works like a dream, Cheers for the help. Cheesy
