port blocking
port blocking
could someone tell me all the ports that plus.net block, any help would be great
port blocking
None.
If your on a homesurf / Bizsurf account then some ports are blocked which relate to P2P apps.
They did block port 135 outgoint from your PC but I don't think this happens now since the Redbacks were replaced by Junipers.
port blocking
cheers
port blocking
I think they do have a holding page, if traffic is detected on your connection using port 135, I also thought port 445 was blocked on the PN network boundaries.
port blocking
yea, both the NetBios ports are blocked, and for the simple reason that all the main worms over the last two years have spread via these ports , and thus it is making the net a bit safer for the isp to kill this traffic as it stops the worms spreading.
Buz
