plustalk help - a catalogue of errors
pint
Im trying to use the plusnet phone thngy (with X lite) and all that i can get from it at the moment are nothing but errors.
Usualy its error 403 forbidden, or Error 403, we dont accept private con
can anyone help?
pint
the sodding thing still isnt working, this time its coming up with error 407 proxy authentication required, it was working before but now its not working at all all that it comes up with is error after error.
gary
Sorry to hear your having problems.
The error you are getting is happening because xlite is broadcasting your internal privrate IP to the VoIP platform which is why its saying "we don't accept privrate IP contacts.
To fix it, on the topology tab of xlite select "discover global address" and then set the stun server to stun.counterpath.net
Let me know if this fixes the problem.
pint
I couldnt find a topology tab although i did managed to change the STUN server, and it worked for a bit.
However today its coming up with yet another error message:
call failed error 407 proxy authentication required.
What i cant understand is that its worked before without changing any settings ( such as the stun server) why isnt it working now?
pint
Error 408 time out
pint
Error 408 time out
It was working, now its not, why?Huh
pint
error 408 time out
