php
php
hi
does my website function support php
please can anybody tell me
im on home buisnes 1000
1 REPLY
php
You will need to enable CGI access to use PHP. This is on a different server than the homepages server. If you have a doman name, you can use the Domain names portal tool to use the CGI server - if you find this a problem, raise a Contact us ticket to get support to help you.
Also check out the Tutorials and CGI Forums and the PlusNet Support pages.
Good luck!
Neil
