pap2
pap2
someone please help me set this damn thing up.
I keep any an error along the lines of cannot connect to login server.
I've got the ip address of the pap2 setup as DMZ, and I've setup port forwarding on UDP 5060-5061 and the stun port 3748.
In the pap2 I have these settings;
proxy: sip.plus.net
outbound proxy: sip.plus.net
use outbound proxy: yes
Display name: littlened
userid: 211257
authid: 211257
password: my password
use authid: yes
stun enabled: yes
stun server : stun.sipgate.net
my router is a netgear dg834g
pap2
I got it working, but dont ask what I did
pap2
I tried all sorts too.
In the end, I think changing "Substitute VIA Addr:" under advanced view, admin login, SIP tab, to YES
It doesn't matter (for me) weather I'm in DMZ, ports are forwarded or none of those things, it still (kinda) works ok. Also, it doesn't matter (for me) weather I use the number or plustalk at the login.
Sure, the service is still pretty flaky (compared to sipgate over the plusnet ADSL) but it's a good start.
Hope this helps.
