p2p
p2p
any body know a good isp for p2p ? plusnet are a load of rubbish,i wished i had never moved from my old 512k connection
p2p
Topic moved to a more apt forum.
p2p
Depends what kind of P2P you mean, gaming? skype? or illegal file sharing?
p2p
I too have asked the same question as I occasionally use Limewire but have been unable to after moving to PlusNet about 2 weeks ago. Is there a reason for this?
p2p
yes
1)limewire is rubbish
2)P2P speeds on plusnet are routed through their network on the lowest priority compared to all other packets, as well, they are useless packets anyway.
3) Change ISP if you want to download a load of stuff over P2P, PlusNET dont say they are good for it, and if you had taken a gander over at adslguide you would know that already, so .. hah :p (request your MAC and hop off to Nildram or Zen or... other ISPs that dont traffic shape P2P to where it should be, the bottom of a network stack.)
p2p
Thanks for that Buzzons, but according to the adslguide option 1 is supposed to give you max available line speed even on p2p.
