outlook not recieveing emails
need some help here its been working fine but recently we know emails are being sent but when on another account and you reply it always says no messages when you check for new emails on this account
in account settings
mail.plus.net is the incoming
relay.plus.net outgoing
scottie3@bikersville.fsnet.co.uk is the email address in the general settings
only thing i can thinkof is that for some reason i
theres a problem using the fsnet email mabye ?
any info you need just ask but i could do with some suggestions
we can send but cant recieve
vic_newey
see some of my posts earlier this week, my e.mails are disappearing also !
You need to go on and use webmail to see if the emails are getting to the server.
It could be they get to the server and outlook doesnt download them you need to work out which is the problem.
Putting the wrong email address shouldnt effect it but then evryone will reply to that address and you are then not getting replys to plusnet. So if you send a email and the user clicks reply it wont go to plusnet
