netobjects fusion7
Brickinit
netobjects fusion7
i'm tring to do a website for a local club, having tried frontpage and managing to get things started and a couple of pages uploaded and working,then trying to modify and crashing it ( all you get on website is a blank colour then if you click on it you get all the code ) i gave up and tried fusion7 which gives some fair looking results for a novice. but after publishing to my hard-drive as per tutorial, it says"could not connect to ftp.plus.net/" any ideas
malc
netobjects fusion7
Is the trailing / after ftp.plus.net anything to do with it.
Have you configured the login name and password for using ftp? DOn;t knoe about the product so just guessing here.
Windows has a command line FTP client called ftp so If you try manually to use FTP does it work?
Brickinit
netobjects fusion7
thanks very much Peter you hit the nail on the head it was the trailing / . and then having to put in /htdocs as it didn't like being left empty.
again many thanks
malc
