mySQL details..
mySQL details..
I dont know my mySQL details, can anybody help?
mySQL details..
Use link:contact us and inform them you no longer remember the details.
They should be able to re-issue a new password, and send out the details for your account.
Plusnet Staff
Plusnet Staff
mySQL details..
If you give the support team a call or raise a ticket for you we can reset it for you. Unfortunately we don't store a copy of the original so if you're using it on your CGI site you'll need to update your config files.
csogilvie
mySQL details..
However, you could then just open them first and get the password from them if you're already using it Wink
Plusnet Staff
Plusnet Staff
mySQL details..
Good point.
