msipcsv.exe Anyone familier with it ?
ZA suggests it is a programme I have allowed yet when I removed it from ZA and rebooted it automatically allowed it again. hmm.
What is msipcsv.exe ?
A quick search of the net indicates it is spyware
Extract from one site:-
MSIPCSV.EXE is, from what I can tell, part of what is known as "Spyware".Otherwise known as the stuff that comes attached to lots of "freeware" that shows advertising while you are using the product, and/or collects marketing info. Aureate, etc. All I can tell you is that my "Spyware" removal program looks for that file (among many others) and suggests removing it.
Try Adaware or Spybot :
ok
it's zone alarm allowing it yet i cannot find anything relating to it.
Start in safe mode and remove the file MSIPCSV.EXE (better to rename it to MSIPCSV.EX_). Restart the PC and remove the item from ZA's programme list.
call up your reg editor by using run and then typing regedit.
MESSING WITH THE REG EDITOR CAN CAUSE YOUR COMPUTER SETTINGS TO BE LOST and a format will be needed.........CAREFUL........DONT TOUCH ANYTHING other than the advice given..................
open the following folder in your reg editor.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnceEx
sometimes they write themselves in there. if the named offender is there, then right click and delete.
i take no responsibility for anything going wrong as a result of giving you this info. :roll: Wink
