ms outlook 2003
ms outlook 2003
hi i cant recieve emails through my account yet im getting them in webmail my dad who is useing the same pc can get them in his outlook so why not mine does it take time at plusnets end to set up or something saying that when i set up my dads it was doing the same not recieving emails untill 2 days later everything was fine can someone please help me
ms outlook 2003
ms outlook 2003
Assuming you both have seperate email accounts you should send and recieve with no problem. You set the password to username+mailboxname so your username is paulclarke1951 and your mail account is paul you would logon in outlook to get your mail with paulclarke1951+paul and use your main password that you use to connect.
If you dont have seperate acounts you need to go onto the portal and add one for your self it only takes a few hours for your mail box to work but of coares people have to email you at the new address
