message boards help
message boards help
iv uploaded phpBB2 to my webspace done everything it says in the instructions, then it says go to http://www.themusic.plus.com/phpBB2/install/install.php to install the message board but i get this error
Not Found
The requested URL /phpBB2/install/install.php was not found on this server.
Apache/1.3.26 Server at www.themusic.plus.com Port 80
does anyone know where im going wrong?
Jim
message boards help
You have uploaded it to your normal webspace, it wont work there.
You will have to activate your cgi webspace and upload it there.
Jim
message boards help
When you say "my webspace" do you mean your cgi webspace? as php will not work on the main server. It has to be insalled on the CGI server.
message boards help
iv activated it and now it has loaded i get .
Database themusic_pn - Table test running on humbug
Structure Browse SQL Select Insert Export Operations Empty Drop
what do i click on?
thanks ( i know nothing about computers) sorry
message boards help
You will get an email from PlusNet giving you details of the password and database name for the mySQL space.
After activating the CGI space you need to wait up to 4 days for it to become active.
After that follow the tutorial available Here
message boards help
thanks.
i recieved my password last night.
and the topic doesnt exist that u posted
message boards help
It does now. try again.
The link from the Tutorials index is wrong so I have corrected the url manually.
message boards help
is this my <CGI server name> themusic@physweb1.cgi.plus.net?
themusic@physweb1.cgi.plus.ne.criticalmass.plus.net Huh?Huh
message boards help
No, you would use http://cgi.themusic.plus.com to see anything which you have uploaded to your CGI space.
message boards help
However, that doesn't work. I think what you've done is you've activated your MySQL Database but not your CGI Space.
To activate the CGI space, go HERE, click CGI, and then press Activate.
message boards help
hi iv had my cgi activated and im having a few problems.
its saying http://cgi.themusic.plus.com isnt supported in my ftp software.
when i type it into my web browser its just a list and there is no login choice.
how do i access it?
message boards help
You should be using cgi.plus.net to call it up from your FTP program.
I use Cute FTP which works fine with the cgi space for uploading.
You can download a trial version of this that is fully operational for a month and see if that works if your current one is giving you problems.
message boards help
alright last question then im giving up. iv uploaded the gzip file or whatever.
iv used the custom commands but i keep getting Syntax error, command unrecognized.
i went to new commands in cuteftp. made these
tar xvzf phpBB
telnet cgi.themusic.plus.net
telnet
it did say make them
drive:\dir> telnet <CGI server name>
[Connecting]
i tried that but it said 500 DRIVE:\DIR not understood
COMMAND:> tar xvzf phpBB
500 TAR not understood
500 TELNET not understood
ERROR:> Syntax error, command unrecognized
message boards help
You should try using those commands in telnet, they definitley work there. The FTP client way only recognise a few commands, tar probably not being one of them.
message boards help
ok as i have got a little bit further im gonna post another error.
[Connecting]
Linux 2.4.22-5um (shell1.cgi.plus.net) (14:33 on Thursday, 01 January 2004)
login: themusic
Password:
themusic@shell1 themusic $ tar xvzf phpBB-2.0.6.zip
gzip: stdin has more than one entry--rest ignored
tar: Child returned status 2
tar: Error exit delayed from previous errors
it says that in absolute telnet.
