mIRC expliot found
mIRC expliot found
There is currently an vulnerability circulating for mIRC, it means that people can cause all versions of mIRC to crash at will. To protect yourself from this add "/ignore -wd *" without the "s to your perform. For more information check http://www.irchelp.org/irchelp/mirc/exploit.html
If you cant update cause of a script not working with mIRC 6.12 then do the ignore temp fix in the quote but otherwise update to 6.12 asap.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
