lost domain anyone seen it?
I register wingchun-tao.co.uk as part of the free domain from plus net. The website is up and running and I registered it with Nominet.
No email works it bounces back and whois searchs all say I can buy the domain
Its hosted on plus net
Can anyone check to see if they can see www.wingcun-tao.co.uk as it still seems to be missing as does the email. I have raised a ticket but after a week its still not there
holdtight
Nope its not there " server not found "
p_w_d_stone
No match for "wingcun-tao.co.uk".
This domain name has not been registered.
WHOIS lookup made at 00:00:05 11-Jul-2007
This WHOIS information is provided for free by Nominet UK the central registry
for .uk domain names. This information and the .uk WHOIS are:
Copyright Nominet UK 1996 - 2007.
You may not access the .uk WHOIS or use any data from it except as permitted
by the terms of use available in full at http://www.nominet.org.uk/whois, which
includes restrictions on: (A) use of the data for advertising, or its
repackaging, recompilation, redistribution or reuse (B) obscuring, removing
or hiding any or all of this notice and (C) exceeding query rate or volume
limits. The data is provided on an 'as-is' basis and may lag behind the
register. Access may be withdrawn or restricted at any time.
I'd raise a ticket with CSC to find out if the free domain component is still on your account and try and register the domain again.
Don't know if any PlusNet staff are able to check what happened to the original registration.
Yep it's still not showing up as not registered at all.
I'd get someone at PlusNet to look at it.
grimme
Yes, both wingchun-tao.co.uk (see 1st post)
and wingcun-tao.co.uk (2nd post) are showing as "server not found"
It's looking as though PlusNet need to find what's happened to it.
Plusnet Staff
Plusnet Staff
Fixes: 159
Shows up for me.
http://winchun-tao.co.uk/
I'll try sending an email to it too.
*edit*
Emails are also being received to it without problems.
 Chris Parr
 Plusnet Staff
Ahh - mwright's mis-spelt the domain on the second post, which is why we all thought it hadn't been registered at all Wink
But yes, the site works at least.
grimme
In the first two posts, looks like mwright had an extra g he didn't know what to do with! :lol:
Or mwright made a mistake and registered the wrong name i.e. without the g but it should have been with the g.
grimme
Yes, looking at the web site, I'd say he probably does want the extra g!
I wonder how PlusNet would change it as part of the Free Domain request, if he really wanted it as detailed in the first post?
Plusnet Staff
Plusnet Staff
Fixes: 159
Unfortunately once the domain is registered it can't be changed.
A new domain could be registered, however this wouldn't be on the free offer.
 Chris Parr
 Plusnet Staff
I dont know how i managed to register it without the r 3 of my mates have looked at it and they didnt see it was wrong. The problem is you read what you think is there.
I want new glasses or a new brain
