linksys pap2t
linksys pap2t
I have the plusnet broadband phone working on x-lite but have just bought a linksys pap2t - several tries at getting it to work; so far failure.
I have the phone connected to the ATA and have the admin page I have (I think) entered all of the necessary connection stuff but It just does not dial.
Wonder if there is anyone out there who is willing to give me a hint.
It didn't help that the supplied CD was unreadable - but even after finding a set of documentation Huh? on the WEB it is so unhelpful as to be useless.
Thanks Allan
Fixes: 45
linksys pap2t
Have a look at this :- http://www.plus.net/support/hardware/linksys_ATA.pdf
Hope it helps.
linksys pap2t
linksys pap2t
thanks - it worked
linksys pap2t
I;m on the verge of buying one of these, there seems to be a lot on ebay from hong kong at virtually half the price I can find on uk sites, anybody tried one of these or can any1 foresee any problems with buying the ebay models?
ian007jen
Pap2t
linksys pap2t
Yep thats the one I was looking at Smiley
The ebay ones work out at about 18 quid but I'm a bit of an ebay virgin Shockedops:
Just wondered if any1 had bought these hong kong models.
ian007jen
linksys pap2t
Honk kong items on ebay ?. They can be a bit of a hassel, i tend only to buy from UK, you may have to pay import duties, may take 10-14 days to arrive, It may be twice the price but they may offer better support returs etc.
Ian
Fixes: 45
linksys pap2t
awb70uk,
If you want a cheap and cheerful ATA I got a Voyager 10v at £4.99 on ebay and it works a treat
( once youve coaxed it away from its dependance on BT , see here http://www.voipuser.org/forum_topic_5206.html )
This is where I got mine from ebay.co.uk
He was originally trying to sell them at £12.99 and didnt sell any, then dropped them to £4.99 when I bought mine,
so if he doesnt sell any at £9.99 he may drop them back to £4.99.
Best thing for me was he is only 10 mins away so collected and didnt have to pay postage.
[Moderator's note by Jonathan (chillypenguin): Long URL Converted to a link. title.]
linksys pap2t
Thanks for that well worth looking into.
I have a BT buisness 220v here aswell which I unlocked using a firmware patch, can the 220v be used for non bt sip accounts do you know?
Fixes: 45
linksys pap2t
A quick google would indicate - yes.
Take a look here http://www.voip-info.org/wiki/view/VOIP+Routers
towards the bottom of the page are some details about setting SIP configuration using Telnet , very similar to the 10v.
If its any use I had to set the 'tel number' in the 10v config to my plusnet sip id.
linksys pap2t
Thanks Cool I'll try tommorow, looks a bit daunting bit I'll let you know how I got on.
