keep getting kicked out of Ebay
I'm trying to sell something on ebay, but everytime I go to the Sell section, my internet connection shuts down?!??
I have NO idea what is causing this. Could it be something to do with Norton anti-virus?Huh
It is easy anough to prove/disprove by right clicking the Nortons icon near your clock, and selecting "Disable auto-protect", then see if you can get through!
Don't forget to re-enable your Nortons afterwards.
BTW you will need to do this using an admin account.
Regards.
well it's not that! Just tried it and the same thing happened.
I'm confused :?
holdtight
Is it only this part of the web that you are having trouble with ie just selling on ebay ?
If yes i would say its possibly a corrupt file in the browser cache so try deleting all cookies and cache reboot your system and try again
Bill.
that didn't work either
holdtight
So is it just the "sell your item" part of ebay out of the whole internet that you cant use ?
sell items is the only place I've had problems with so far
any more help then?Huh
what firewall are you running? what browser are you using?
Switch to a different browser, if your using IE then get Firefox, if your using firefox updatye it to the very latest version, Clear your cookies, temp internet files, reset IE back to Defaults, the usual stuff that CSC will ask you to do if you contact them.
