keep getting inbound from 84.50.6.34
Thanks for the fast reply. No i'm not using any P2P software at all. The only things runing are messenger, outlook, Wallwatcher( reads logs from router). Norton Internet security.
This keeps ahowing up in my inbound logs but i can't find any info about this ip could someone please tell me wher to look.
http://www.dnsstuff.com/tools/whois.ch?ip=84.50.6.34
It's a dialup pool from a company called Elion Enterprises Limited based in Estonia
Are you using any P2P applications, where this may be a connection attempt for P2P data?
P2P networks are known to cache data for quite some time after disconnecting. It is thus very easily possible that you will see attempts for a couple of hours after closing the software
