isp for domain registration
Please can someone recommend a good isp for domain name registration. I want to be able to have good control over maintenance and be able to transfer in domains. Thank you.
http://www.123reg.co.uk/
I use these, though they are now owned by the parent of Pipex.
Philip, thanks for your reply. can anyone recommend any others?
http://oneandone.co.uk £1.99+VAT/year
For .co.uks I would also recommend OneandOne. For .coms, .nets, etc. I use www.godaddy.com - $8.95 (about £5 at the current conversion rate).
thanks - do you know what these are like for transfers in?
123Reg where simple when we did it., although there was a charge for inward transfer IIRC.
We did this back when 1&1 had a very poor domaina managment system, so moved it away from them.
I've used 123reg's domain management and it looks good. Is 1&1's up to this standard now do u think?
Couldn't tell you. But I know they have added a lot of new controls, including the controls we needed when transfering to 123Reg.
I would go back with 1&1 now, because of these changes.
Thanks everyone who's commented - much appreciated.
Allen
lowry
I have about 6 domains with 123-reg.co.uk and my experience with them has been positive. They used to forbid changed to DNS, but now they let you change name servers, mx records, etc direct from the 1&1 control panel (which is pretty good). £1.99 inc. VAT is a very competitive price for a .co.uk domain too.
matt Wink
