interne connection monitor
im not at my computer much but i leave the net running all the time. id like to be able to return from somewhere nd check how many times or if any my connection has dropped or how many minutes my connection has been on without a disconnection.
is there any good software out there to give me this information?
Alecto
Put your router/modem model number into google and see if it has a log.
This may give you what you want to know.
This info can only be supplied by the router and not all are very good at doing this. Without knowing what equipment you have that's all we can say
As suggested above, check the router logs.
i have a bt voyager 105 modem.
I don't think that USB modem has any logging capabilities from what I can remember.
holdtight
No your right Peter they dont
Alecto
But I can't really understand what you will gain by this information anyway.
If it's not cutting you off all the time while you're using it, then why bother what it's doing when you're not there? :roll:
holdtight
I agree with Geoff i cant see what you will gain from this info but give This a try
install it set it to capture then just minimise it and it will give you a complete list of whats been through your connection
