index.htm not displayed
glocal
Can someone tell me why IE6 will return <http://webspace.plus.net/webspace_plusnet.html> instead of my root index.htm when accessing <www.user.plus.com>? Strangely enough Mozilla Firebird, OffByOne and Lynx return index.htm as they should!
I'm testing them now side by side and refresh the cache but IE won't get over that plusnet Welcome page.
Michael
This is a cache issue in your browser.
Are you manualy deleting the files, or using the cache delete feature?
Note: The disk cleanup wizzard is the same as manual deletion. You will need to use the delete feature of IE.
It displays a "Unspecified or unknown <path>" error message, which looks custom by yourself.
glocal
It works now -- false alarm
Oops! sorry about that. It works now. Weird! Whatever I tried earlier,
it wouldn't fetch the new page. Now that I deleted manually the relevant
files from the cache, it worked.
Thanks.
Michael
