ie settings
keithivan
ie settings
Can anyone help
I have a network of computers , my daugters has xp on it. She is able to view some web sites but not sites with active server pages. I have tryed changing ie settings but have been on 3 hours now without success. Any help would be welcome. My other 2 pcs have ME on them and work ok. I am using ic sharing on one of the pcs and have an isdn connection. Cry
ie settings
Could be the firewall if it xp? :?:
Try turning it off and see if that helps.
if it does then you will need to adjust it so that it works to your liking but still offers protection.
keithivan
ie settings
thanks for the info john but plan b is now in operation "system restore disc used" Now setting up the network etc. Seems to be working so far. ie seems to be accessing all sites now . (bottle of wine seemed to do the trick). :lol:
ie settings
Drinking or smashing it on PC?
both is good.
ie settings
No you have to get the order right.
Drink it first and then smash PC with empty bottle
